crappy fuel guage...
Old Dec 12, 2002 | 12:31 AM
morb|d's Avatar
i have a '98 and my fuel guage is anything but accurate. it stays pegged at full about half way through the tank (about 8 gallons from full) and only then starts actually moving down. so when the guage gets unpegged, it actually means i have half a tank of gas left.
anyone else have this? know how to get around it? maybe there is a faulty sensor i could replace for cheap?
Old Dec 12, 2002 | 04:03 AM
Soma07's Avatar
There is nothing wrong with it, all 4th gens i've seen are that way. I'm told its because the tank is shaped like a big V, since there is so much more volume at the top it the level drops much slower than it does towards the bottom.
Go GM
Old Dec 12, 2002 | 04:27 AM
morb|d's Avatar
another reason gas should be guaged by weight instead of volume.
thanks for the info. :/
Old Dec 12, 2002 | 08:25 AM
stale's Avatar
Yup, I've got a '96 Camaro and I have the same problem. At least you haven't run out of gas yet thinking you still have 1/8th of a tank left.
Old Dec 12, 2002 | 09:43 AM
95GRNZ's Avatar
Exclamation
Perfectly normal.
TS
Old Dec 12, 2002 | 02:23 PM
ibanez6rg's Avatar
Yea mine goes wack after it goes below 1/2. I'll slow down and turn, then it will be on empty Go GM! Woohoo!
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Jun 6, 2015 08:27 AM
NewsBot
May 16, 2015 04:00 PM
ad356
Apr 16, 2015 05:38 PM
