very low fuel pressure
Old Jan 6, 2008 | 09:37 PM
2nd 2 noss's Avatar
i have a 96 z28 5.7 lt1, when i go to start car i have to wait, like the fuel has to get there. then it starts and runs great. will this be the fuel pressure regulator or fuel pump? i can tell you I dont have pressure when i release pressure valve.
Old Jan 6, 2008 | 09:58 PM
If you are sure there is no pressure - a pressure gauge would tell you more than simply pressing the valve core - then is could be a dead fuel pump, or a failed fuel pressure regulator. But since it eventually starts, and "runs great", it may not be either.
Why not put a fuel pressure gauge on it and find out exactly what is happening? It could be a faulty check valve in the fuel pump allowing rail pressure to drop to "0" on shutdown, leaking injectors, etc.
Old Jan 7, 2008 | 07:49 AM
AL SS590 M6's Avatar
How about a plugged up fuel filter??
Old Jan 7, 2008 | 11:13 AM
If the fuel filter was plugged to the extent it prevented any pressure at startup, and extended the startup period, its sort of hard to understand how it would provide adequate fuel once the engine started, allowing it to "run great". But never hurts to check it.
Old Jan 8, 2008 | 07:26 AM
I understand that but I always start at the simplest part of a system first especially when it's an often over looked maintainence item.
Old Jan 10, 2008 | 09:38 PM
2nd 2 noss's Avatar
ok so i thought it will be a good idea to cheange filter since it looked to be original.. so that was not the problem... i have to get a fuel pressure gauge.. i can tell that the starting is starting to take a little more time.
Old Jan 11, 2008 | 04:17 PM
Bossdawg6669's Avatar
Verify a drop in fuel pressure via a gauge. If it is dropping, swap the pump out. Should be fairly cheap and easy.
Old Jan 13, 2008 | 05:32 AM
aboadnan's Avatar
Check pump rely , does it happen when cold or sitting for long time
if so you have to wait untill oil pressur swich turns on the pump,
one way to check is to turn ignition on (don't crank) and hear if fuel
pump primes.
Old Jan 14, 2008 | 11:55 AM
2nd 2 noss's Avatar
it does it when i let it sit long.. or over night.
Old Jan 19, 2008 | 01:19 AM
aboadnan's Avatar
Did you check if the pump pimes ( if it turn on for a few second and turn
off) When ignition on and engine not running.
Old Jan 22, 2008 | 01:50 AM
2nd 2 noss's Avatar
sound like it is priming.. i just have to get a pressure gauge
Old Jan 22, 2008 | 11:12 AM
aboadnan's Avatar
So either the hose inside the tank has got a tiny hole or you pump
need to be changed.
Dec 1, 2016 05:37 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
IDOXLR8
Aug 6, 2002 12:30 PM
