Racetronix 79# injectors?
Old Jan 2, 2008 | 11:06 PM
reamo04's Avatar
135-INJ-L79FM-8 Racetronix Flow-Matched 79# Style Fuel Injectors (Set of 8)
-Static Flow Rate: 76.65 lb/hr = 9.67 g/s = 846 cc/min (+/-4%)
-Coil Resistance: 12.2 Ohms (+/-0.35 Ohms) (This high-impedance injector will work with all factory ECM/PCM injector drivers)
-Dynamic Flow @ 2.5ms PW @ 100Hz: 16.88 mg/pulse +/-10% @ 2.5ms PW @ 100Hz
-Gain: 0.11ms/mg, Offset: 0.055ms, Turn on time: 1.14ms @ 14VDC, Turn off time: 0.85ms @ 600KPa
-Dynamically flowed and grouped to within 1% tolerance using Racetronix custom injector flow bench
JW if anybody is using them.
Building a MP T70 turbo setup and am wondering if i should go with 60# siemens injectors, or the 79# racetronix for safe measures
Old Jan 5, 2008 | 01:01 PM
Funkybird's Avatar
I think I might get them. I'm shooting for 700rwhp and everyone I talked to says 60's wont cut it at that power level. How much power are you tryin to make?
Old Jan 5, 2008 | 02:35 PM
reamo04's Avatar
well, im going for 650RWHP or so and wasnt sure if 60#s was enough
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
