Need replacement for Baer rotors
Old Dec 20, 2007 | 07:00 PM
weq92f's Avatar
Some time ago I installed a Baer kit on my 94 TA. Nice big rotors and really great performance. Since I've been driving the car again regularly after a couple of years of disuse, I'm thinking of a brake job. The problem is, Baer wants 160 each for a set of relpacement rotors! That seems excessive to me. I may be able to thave them turned but I've got other issues with that.
Any advise on how I might go about finding a less expensive rotor that will fit my modified-from-stock configuration? If I remember correctly the rotors are just over 13" and no changes to the hub were required ( aside from slicing off the bracket for the OEM calipers, so all I need is the right size rotor with the same bolt pattern, right? Or am I missing something?
Thanks
-Kevin
Old Dec 20, 2007 | 07:35 PM
weq92f's Avatar
If I'd just read down a bit... Found a similar post in here from a while back. Still, I wonder though if I could get lucky with some GM OEM rotor, like maybe for a vette or something?
Thanks,
-Kevin
Magenta_Hearts
Mar 25, 2015 10:24 AM
dale3in98
Feb 14, 2015 12:18 PM
Jazsun
Dec 29, 2014 12:14 PM
ScottZ
Mar 3, 2004 01:34 PM
