getting rid of fmu and need bigger injectors with tune
Old Dec 12, 2007 | 02:58 PM
mrmint69's Avatar
I am getting a mail order tune and he recommended ditching the fmu and going with bigger injectotors. I plan on upgrading my heads, cam and forging the bottom end later than sooner. Hoping to get 400 or so HP eventually. What size injectors would be best for right now and also work on the new setup?
Old Dec 12, 2007 | 05:44 PM
I think you will get better results on "Forced Induction". Moving..........
Old Dec 12, 2007 | 10:10 PM
Boosted_Z28's Avatar
42lb. injectors worked well for me when I ran my P600-B on the stock 350 ci motor and 10lbs. of boost.
Old Dec 12, 2007 | 10:36 PM
mrmint69's Avatar
I thought 10lbs on stock bottom end = . I found a set of Bosch 36 lb for $300, so what do you think of this brand and size? They say 425 to 475 hp so i would guess they would fall right into my future plans. The injectors are mfg. rated at 36lbs/hr (at 43.5psi, 3 bar), and flow tested at better than 2% tolerance. Bosch 0280150967 - 36lbs/hr Pintle-style Fuel Injectors Matched set.
Old Dec 12, 2007 | 10:39 PM
1982z28with18s's Avatar
My 42's will be coming out after this weekend, $225 shipped for them if you want, they should support what you want just fine.
Old Dec 13, 2007 | 07:01 AM
95zpro's Avatar
42#'s will work great; for me the fmu was a huge restriction. I think you will be happier and driveability should improve.
Old Dec 13, 2007 | 06:46 PM
Intercooled and a conservetive tune worked fine for me but every car is different. I would recommend 42lb. injectors. If you over build your system by a small amount at least you'll have some room to grow.
PublicEnemy1
Apr 7, 2015 12:21 PM
drptop70ss
Mar 26, 2015 01:50 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
k1996z28
Jan 21, 2015 07:22 AM
SC97TA
Sep 15, 2002 01:10 AM
