Wastegate and BOV Size
Im looking for some wastegate and bov help. Im looking at a xo2 racing 44mm wastegate because Im going to be running low boost 6-7lbs with a MP t70 so it should spool pretty fast. I just want to make sure that the wastegate will be sufficent because all the bigger ones start with 9lb springs.
And for a bov reccomendations as well. Turbo newb sorry.
Aside from the spring issue, a 44mm gate will be fine. Justin had no problem running low boost with his 44mm gate.
Supposedly Jose at forcedinductions used a turbosmart 38mm on his 383 setup.
For a BOV... anything really. You could get the 50mm Tial, the 50mm XO2 BOV, the JGS BOV. You could also look into the Raptor BOV and some of the other Non Tial style BOV's
Mine have round heads not hex, but the same design. Downside is they do not bolt or clamp on, but with just hoses and good clamps they have stood up to 10psi a few times so far.
http://cgi.ebay.com/ebaymotors/BLOW-...em230200651045
So far my 70 has made boost incredibly fast. I fear it is a bit small for a heads/cam small block. But we will see where it goes.
Their wastegates (particularly) the 60mm is based of the HKS design and uses the HKS springs (which 9psi is the smallest). Sounds like you can use a Tial spring on the 44mm though.
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
