transmission slipping
Old Dec 1, 2007 | 06:47 PM
Michael982's Avatar
i can feel my transmission slipping when im cruising at about 40 miles per hour and also sometimes when i decelerate im thinking about buying this rebuild kit do yall think it would help
https://www.700r4l60e.com/store/prod...&cat=55&page=1
Old Dec 1, 2007 | 06:49 PM
Michael982's Avatar
also would i need a vacuum modulator
Old Dec 1, 2007 | 08:10 PM
FivePoint7z28's Avatar
Are you rebuilding it yourself?
Old Dec 1, 2007 | 08:18 PM
Michael982's Avatar
i think i might have my dad do it cause he owns a mechanic shop and used to rebuild transmissions
Old Dec 2, 2007 | 01:37 AM
Pro Built Automatics's Avatar
You will not need a vacuum modulator here, the pcs will do fine.
Old Dec 2, 2007 | 08:19 AM
Michael982's Avatar
will this kit solve my problems and out of curiosity what does pcs stand for
Old Dec 2, 2007 | 11:10 AM
12SCNDZ's Avatar
That kit would be Ok for a basic rebuild, but I wouldn;'t want to put any real power through it. Some of those parts are marginal, at best. One thing about that list that's really disturbing is the fact that an SKF input sprag is included. Anyone who's building (or supplying parts) for any 4L60E that sees any kind of HP knows they won't last long. The 3-4 clutch arrangement in that kit leaves alot to be desired. There's definitely better out there, as well as the stock type 2-4 band. I still can't believe people still use the teflon coated pump bushings. I guess they haven't been around 4L60E's enough to see how many of them fall out of the pumps.
$500 seems a little high for a bunch of stock rebuild parts. For that much money, you can build a transmission with ALOT better parts.
Frank
CPT
Old Dec 2, 2007 | 07:17 PM
Michael982's Avatar
which kit would you recommend for mainly street use but also strip use every once in a while
IndyZman
Oct 22, 2015 02:17 PM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
