D1SC and Bypass Valve
I have a D1SC with the twin IC setup running 8-9 lbs. boost. I'm planning to do a FMIC and crank the boost up to 14-15 lbs. (maxed out). Will my ProCharger BPV work well with this boost level or should I consider going with a Vortech Mondo BPV?
Which Procharger by-pass valve are you currently using? If is is the standard unit that ATI sends with their kits (Ford vacuum actuator), I would consider upgrading to a better quality BPV . I've never really liked the design of the standard ATI BPV and with higher levels of boost, they just don't appear to be up to the task.
You could either use another one of the standard bypass valves (ATI calls it the ProFlo surge valve), or take a look at ATI's Race Bypass Valve.
http://www.procharger.com/component_photos.shtml
14
Aug 11, 2015 12:03 PM
