Coolant leak at TC
Old Nov 23, 2007 | 01:47 AM
user name's Avatar
Coolant leak at TC
Howdy,
Just a quick question. The car is a '94 3.4L auto. It's got a coolant leak at what appears be to the timing cover. If I look at the upper heater hose leaving the pump (passenger side), then look into an alcove in the block just above that hose, I can see and hear coolant peeing (it's higher and deeper than the pump itself).
Is this a common place to spring a leak? Does it sound like the TC gasket is leaking? Anything else it could be?
Thanks for any and all ideas. I'm sorry to not have a picture for you guys. I know that would make it a ton easier to know what I'm talkin about.
Old Nov 27, 2007 | 12:13 PM
smithtim's Avatar
not sure from what your saying and like you said a picture would help. But, I'd say that you want to be very careful to check that your not leaking coolant into enginge / oil (i.e. intake or head gasket); as if you are an you continue you to drive it big problems
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
