removing Interior any advice?
Old Nov 16, 2007 | 08:46 PM
Oxygen454's Avatar
Ive had water in my car have to track the problem... is there anything I should know about removing the interior and what is all involved? Are the seats easy to take out? I also have to remove the plastic siding inside the car... looks like the leak is running down inside the walls of the car (behind the plastic)
Old Nov 19, 2007 | 11:54 AM
teke184's Avatar
isn't really that hard. i pulled all of mine out when it flooded in the hurricane
plastic is mostly just screws and some small bolts.
the bigger bolts should be either 13 or 15mm
the torx bolts for the seatblets will be 47 i think...but a 50 will work in a pinch
you'll have to pull the whole center console out to get the rug. but that's easy once the seats are out.
Old Nov 19, 2007 | 03:55 PM
Mr. Wolf's Avatar
where is it leaking at exactly in the car?
Old Nov 24, 2007 | 10:59 AM
Oxygen454's Avatar
Im not sure looks like its coming in somewhere on the side walls of inside the car and running down to the floor. Might be the t-tops or the rear hatch seal, not sure.
Old Nov 24, 2007 | 11:20 PM
walt355's Avatar
Yeah, It isnt too bad. Ive got my car completly stripped right now for a cage installm The rear seat plastic is help in by velcro, Other than that its mostly Bolts, Screw and plastic fasteners
Old Feb 14, 2008 | 11:29 PM
Oxygen454's Avatar
Found the leak, its coming in between the t-top and drivers window. I got broken into a year ago and the guide wheel snapped. It never got fixed so the window alignment more than likely has something to do with it. The seatbelt is wet near the top all the time when it rains.
Old Feb 15, 2008 | 06:34 PM
Oxygen454's Avatar
Anyone know why the t-tops leak between the t-top and the car siding? Sounds like new seals
Jun 6, 2015 08:27 AM
grabbem88
Feb 10, 2015 06:20 PM
squarehead
Nov 21, 2014 08:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
