TPI plate on LT1?
He is asking about the nitrous plate.
Nitro dave would be a good one to ask.......it will work as far as fit...you need to find out if anything LT1 related will interfere as in the tubing/breather stuff on the pass. side where the lines are
I understand he is asking about the plate....but if he gets a bigger plate then he has a tb.......
no he does not. The plate is bigger then the TB so its no problem......only would be a problem if it was smaller and I think most are 58mm plates only 52 I have seen was a nitrous works. The 48mm will work fine on either
well, can you guys tell me what else i'll need with this setup:
10lb anodized bottle
o 1 fuel solenoid
o 1 nitrous solenoid
o Fuel and nitrous jets (125 and 150 shots)
o Bottle brackets
o 20’ 4an feed line
o Supply lines for solenoids
o Fuel pressure safety switch
o Aircraft style toggle switch
o Blowdown tube
o TPI plate and gaskets
o Relay
o Odds and ends of hardware
o Instructions
o 1 fuel solenoid
o Bottle brackets
o 20’ 4an feed line
o Blowdown tube
o Relay
o Instructions
Just looking at your kit, the main thing i dont see maybe im blind is a wide open throttle switch, a switch that will only allow your n2o to kick in under full throttle,
Another good idea would be a window switch to control at what rpms the nitrous kicks on.
Just to have a functional setup all you would really need is thw WOT switch, but theres plenty of other things that could be had with your setup, nitrousoutlet.com look under accessories.
You also need the Cable Relocation bracket (might be in the package with the plate) this moves your TB Cables forward the distance of the thickness of the plate.
On my old setup, it is a flat plate with 6 holes, 3 to mount the bracket to the plenum and 3 threaded holes to mount the TB cable bracket.
oldschool
Feb 9, 2016 09:21 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
