Why is this so difficult...turn signal replacement?
Old Sep 16, 2007 | 12:41 PM
IRONFIST's Avatar
So I'm not sure why this is so hard, but I can't seem to get the old turn signal out....
I found the clip, I've pushed it in, tried to turn it, tried to pull it out.... nothin works??
Old Sep 17, 2007 | 09:19 AM
IRONFIST's Avatar
Well finally figured it out... if anyone ever has this problem, it's a lot easier to undo three bolts on the plastic curve at the bottom of the car, squeeze an arm in and pull the bulb out.
Old Sep 17, 2007 | 10:54 AM
OMGWTFBBQ's Avatar
I never had any trouble.
The foglights are much harder.
Old Sep 19, 2007 | 08:18 PM
lastZ's Avatar
how did u try to do it before u figured out that little trap door?
Old Sep 24, 2007 | 11:09 PM
OMGWTFBBQ's Avatar
Wait, turn signal? I just reached in the inlet below it and popped it out.
Was easy once I figured out how to turn it.
Old Nov 18, 2008 | 04:29 PM
bluzboy's Avatar
I still can't get mine out '99 camaroSS......Underneath are you talking about the plastic splash guards(?) Or Reach in from the top.....looks like you need to remove Headlamp assembly!!!!!Haven't done that yet!
Old Nov 18, 2008 | 10:27 PM
bluzboy's Avatar
Finally got it after an hour , from the bottom. Got pliers on it to start turning 1999-2008; I'd love it if these damn CFL bulbs would last half as long!!!
Old Nov 18, 2008 | 11:41 PM
IRONFIST's Avatar
yah it's a pain eh, hopefully this thread helps everyone out when they search.
Old Nov 24, 2008 | 11:02 AM
OMGWTFBBQ's Avatar
Jeez. I've never had any trouble. And I got one that fishbowls.
Reach in the slit underneath the housing, and pop it out.
Old Nov 24, 2008 | 11:22 PM
97lt1fanatic's Avatar
lol the way i did mine was turn on the lights put my arm down underneath the light from right beside it and pop it out but i got pretty small arms.
Old Nov 25, 2008 | 02:14 PM
johnny6's Avatar
On 98-02 Camaro's i just pop the headlights out (5 minutes at the most) and everything is right there, i can do both turn signals and foglights in less than 10 minutes.
stangspank
Nov 13, 2015 01:02 PM
NJLT1SS
Sep 11, 2002 02:29 AM
Ryabut98
Sep 3, 2002 11:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
