Problem with brake job...brakes dragging?
Old Aug 29, 2007 | 05:40 PM
Camaro1996's Avatar
Hey guys, so I just did a brake job on my Camaro (fronts and rears) and it seemed like a pretty good job, but then I began to realize that the back passenger wheel is dragging--I think.
Here is what happens: When I'm turning right at a somewhat faster speed (say above 20ish) this really odd noise comes from that wheel. It sounds like a high pitched squeal type noise, my guess is it may be metal rubbing against metal???? I cant be certain. Also, when I am just driving, I can hear what sounds like the brake shoes rubbing against the rotor.
None of the other wheels do this, only the passenger rear.
And finally, when I took the old hardware off that wheel, it was severely more worn down than the other side. I'm not sure if the brake balance is off however, because none of the other wheels are experiencing any problems. Any thoughts?
Old Aug 29, 2007 | 09:58 PM
shoebox's Avatar
Might be a sticking caliper (especially since your old pads were more worn, too). That should have been a clue it needed extra attention.
Old Aug 29, 2007 | 11:49 PM
Camaro1996's Avatar
I took the caliper off and cleaned the two 'brackets' (not sure what it is called) it attaches to. What causes a caliper to stick?
Old Aug 30, 2007 | 05:41 AM
Greed4Speed's Avatar
Did you lube the slides?
A caliper can stick because the piston(s) are corroded.
Old Aug 30, 2007 | 04:40 PM
Camaro1996's Avatar
Yeah I lubed the slides. If the piston gets corroded, what can be done to fix it? Rebuild?
Old Aug 30, 2007 | 07:27 PM
shoebox's Avatar
Yep or buy a new caliper.
Old Sep 4, 2007 | 02:17 PM
Camaro1996's Avatar
Do calipers have to be replaced/rebuilt in pairs, like replacing the brake pads?
Old Sep 13, 2007 | 08:46 PM
FASTFATBOY's Avatar
Make sure your park brake cable is released and not stuck. CHeck it AT the caliper.
David
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
dluna333
15
Mar 13, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
