Rear end alignment
Old Aug 14, 2007 | 10:47 PM
Rashiki's Avatar
Rear end alignment
Recently I had new front tie rod ends installed and had the shop perform a 4 wheel alignment with it. They gave me a spec sheet with the alignment results, and if I remember right ( it was a few monts ago and I can't remember what I did with the slip ) the rear end was off by 10 degrees. Is this normal? I know the factory rear end isn't dead on, but is that a lot? I don't know a lot about alignment , but it sounds like a lot. If I were to install an adjustable panhard bar, will the rear end be able to be brought closer to neutral?
Old Aug 15, 2007 | 09:28 AM
Norm Peterson's Avatar
Without the print-out it's impossible to say what's wrong here. But if anything back there really was 10° off you would not have any problem seeing that something was terribly wrong. Even if you didn't know a single thing about cars.
The tires would be into the sheetmetal if it was a 10° thrust angle error, or the axle would have to be bent so badly somewhere that it would be impossible to turn the axles if it was either toe or camber. Out of curiosity, do you remember which of those was "off"?
I'm wondering if you overlooked a decimal point (possibly due to the printer running low on ink) or if the angle was given in minutes (1/60 degree) rather than whole degrees. The shop that did the work should at least be able to tell you the format of the print-out data or show you one from another job.
Norm
Old Aug 15, 2007 | 10:12 PM
Rashiki's Avatar
Hmm, then I must have read it wrong, there are no obvious flaws and the wheels seem to wear evenly, and it doesn't crab going down the road. I'll have to see if i can find the spec sheet and look it over more closely.
Thank you,
Tim
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
