FMIC Vortech T-trim Camaro setup pics if curious..
Here's some pics of my FMIC setup i'm just about done with on my camaro incase anyone needs ideas or just like to view others work. I clocked my T-trim outlet straight up to the 12:00 position and used 2two 2.75" 90's to go down at the fues block. It then goes down and 90's under the car, along behind the air dam into the passenger side of the intercooler, then out the driver side then back up at the fuse block and into the intake. I moved my MAF back up top and have a bypass valve in the fenderwell where the air filter is. There's also a 4" hard intake pipe/elbow SchrutersLT1 did up for me sometime back along with a big 4" i.d. K&N. My buddy and i fabbed up the intercooler mounting brackets which mount in the old location of the impact absorber bracket. ABS is deleted with the SJM kit. I reloed my MSD to the top of the fender and my NOS solenoids are tucked down below the fuse block. So it's basically 10lbs of S%&@ in a 5lb bag! The intercooler is the popular 24x12x4" core from ebay along with the piping kit, which is 3" from the 2nd 2.75" 90 coming from the charger outlet all the way to the MAF. Hope the links work. Enjoy....
http://s125.photobucket.com/albums/p...rcooler001.jpg
http://s125.photobucket.com/albums/p...rcooler002.jpg
http://s125.photobucket.com/albums/p...rcooler003.jpg
http://s125.photobucket.com/albums/p...rcooler004.jpg
http://s125.photobucket.com/albums/p...rcooler005.jpg
http://s125.photobucket.com/albums/p...rcooler006.jpg
http://s125.photobucket.com/albums/p...rcooler007.jpg
http://s125.photobucket.com/albums/p...rcooler008.jpg
http://s125.photobucket.com/albums/p...rcooler009.jpg
Ken R.
Ken R.
That looks good. It's always good to see other peoples setup as it gives people ideas they would've never thought of...or easier ways of doing things. I'm back in the garage now after looking at your IC brackets wondering to myself "why didn't I think of that?". DOH!
Thanks for the comments guys. I'll post some dyno and track results when i get them. I plan on cutting out 2 sections next to where each fog light used to be to get some good air in there. I'll post more pics when i get the nose back on there. Probably this weekend.
Ken R.
Ken R.
1LEThumper
Jul 14, 2003 12:45 PM
sleeperZ96BT
Jul 28, 2002 01:30 PM
