purchasing 3 piece components-where are you guys mounting them??
Old Jul 28, 2002 | 10:39 AM
sleeperZ96BT's Avatar
Post purchasing 3 piece components-where are you guys mounting them??
im gonna be getting the JL evolution XR components and was wondering where you guys are mounting these. im going to have them in the front just have no idea where they are going. its a 6.5 inch, 4 inch, and 1 inch speaker setup. pics/ideas would be gret!
thanks,
brian
Old Jul 28, 2002 | 11:11 AM
LS1 RULZ's Avatar
Post
That's why most of us go with 2-way components rather than 3 ways (which aren't necessary IMHO). In order to use a 3-way system you're gonna have to have some custom kick panels made that will hold the mid and tweet. The woofer can go in the factory location. And, again, IMHO there just isn't adequate room in an F-body to use kick panel speakers to get the best effect from them. There's just not enough room for your legs AND the speakers.
[This message has been edited by LS1 RULZ (edited July 28, 2002).]
Old Jul 28, 2002 | 11:34 AM
ChameleonGreen's Avatar
Post
LS1 is right. Trying to put speakers in the kicks is difficult in our cars. You probably would get better results from a properly installed 3-way system, but a quality pair 2-way set is more than adequate for most systems. Aside from needing kick panels, keep in mind you will also need more amp power, and maybe some crossover equipment as well.
To help answer your question though, you can buy some Q-Logic kickpanels from www.crutchfield.com However, I recommend doing a web search and trying to find someone else who sells them because you can almost always find cheaper prices elsewhere as crutchfield sells very close to retail most of the time. Also, if you e-mail lacher@lachernet.com he makes custom kick panels for our cars as well.
Old Jul 28, 2002 | 01:30 PM
Post
thanks for the help, i emailed that guy you recommended so hopefully he can help. the Q logic kick panels were for 5 1/4 and $200!!!
brian
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Jan 21, 2015 10:11 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Red97LT1
Aug 7, 2002 05:45 PM
