found random idle miss and dying problem
Old Aug 4, 2007 | 02:32 AM
Daniel6718's Avatar
had to drive it some to make it get worse then the codes appeared...
5 of them, consisting of low res pulse failure, high pulse fail, est ground circuit failire ect
basically opti....it does this after the car idles a few minutes at a stop, after the car is already warm... so im poretty sure its heat related..
question, does anyone know what part is getting hot and failing? is it the optical sensor or what?
ive got another opti sitting right here that idles and drives perfect, but we thought was causing a high rpm studdar (bucks the car back and forth at 4500+) can i remove parts from one a fix the other? or even clean the one i have?
i hate this, its the FIRST opti problem ive ever had besides breaking rotors!
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
nophix
Nov 30, 2014 10:26 PM
MJ_Z28
Aug 8, 2002 09:02 PM
HuJass
18
Jun 24, 2002 09:19 PM
