fuel pump replacement
Old Jul 30, 2007 | 05:16 PM
Carlos26's Avatar
hello,
I'm replacing the fuel pump on my 1997 Z28, can someone give me the right direction for me to find a direct fit, plug and play fuel pump, for this vehicle?
Also, even though the shop will be replacing it, how long does it take? is the labor expensive?, how many hours?
Many thanks.
Old Jul 30, 2007 | 05:23 PM
2000GTP's Avatar
If you are looking for a stock replacement, just go with another factory unit. An aftermarket alternative would be the Racetronix pump which is a direct fit, plug-n-play pump. Shop rates can vary, but it is not a cheap job. I would call around and get some quotes before committing to one place.
Old Jul 30, 2007 | 05:31 PM
dangalla's Avatar
summit sells a walbro 255 for pretty cheap
Old Jul 30, 2007 | 05:46 PM
2000GTP's Avatar
The Racetronix is basically a rebadged Walbro, just it is designed to fit around the LT1 application specifically.
Old Jul 30, 2007 | 05:52 PM
Carlos26's Avatar
Hey guys thanks for the quick replies...
I guess i will go with the Racetronix.
Scottyboy
Feb 11, 2015 10:28 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
