What Snell Rating do I need
Old Jul 30, 2007 | 11:10 AM
Bow94z's Avatar
Whats the up to date Snell rating I need for simple street car at the track?
Any good places to pick up a "cheap" helmet for someone with minimal use at the track
Old Jul 30, 2007 | 12:35 PM
Z-RATED94's Avatar
2005. You can usually find a new cheapy for less than a $100. I did.
Old Jul 30, 2007 | 09:07 PM
Stephen 87 IROC's Avatar
A M rated helmet is all you need. Open or closed face, your choice. Make sure it has a Snell 2005 rating since that's the newest and will last you for at least 10 more years. You don't need the more expensive SA rated helmets.
Check with your local motorcycle shops. An open face M2005 helmet should be under $100.
Old Aug 11, 2007 | 04:57 PM
Bow94z's Avatar
will this one work?
Old Aug 12, 2007 | 09:25 AM
Unless it has a Snell decal on the inside, NO.
Some tracks may allow a DOT helmet for slower speed cars such as 14 second and slower. Contact your local track to find out
If you're buying a new helmet, it must have one of these decals on the inside of the helmet
Old Apr 28, 2008 | 11:59 AM
rock1501's Avatar
sorry for bringing back an old thread but are helmet ratings good for 10 years?
Is my snell 2000 still ok for this year?
Old Apr 28, 2008 | 03:37 PM
The Engineer's Avatar
The Snell 2000 expires 1/1/2012 according to the NHRA rulebook. Also, check-out this link.
WD
http://www.nhra.com/tech_specs/ETQuickRef.html
Old Apr 28, 2008 | 04:38 PM
CamaroRacing12's Avatar
u need a SNELL 95 or newer
Old Apr 28, 2008 | 04:42 PM
mdacton's Avatar
I still have a 2000 too.
Old Apr 28, 2008 | 08:03 PM
Snell 95 is obsolete in NHRA and IHRA for 2008. Minimum requirement now is Snell 2000 or K98 (Karting helmet).
If you still have a 2000 rated helmet, it's still good. If you need to go buy a new helmet, look for a 2005 rating.
Old Apr 29, 2008 | 07:45 AM
As pointed out above, the Snell 95 helmet is "already" expired.
WD
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
karpetcm
Aug 14, 2015 03:02 PM
Aug 5, 2015 08:35 AM
