Weird Opti Question...
Old Jul 25, 2007 | 10:58 AM
02BlkBullet's Avatar
Hey guys,
I bought a replacement opti from a guy on this board and I ran into a problem that I haven't ever see/heard of before. I took the cap off and made my alignment marks. It just so happened that it was at TDC which was also straight up and down on the rotor. I went ahead and took everything off and looked at the alignment pins of each and matched up the replacement's rotor with the old opti's rotor. Well, the problem is that when I do that, the alignment pin grooves are different...way different. They are roughly 100 degrees off from each other. Should I install the new opti using the alignment groove and ignore where the old rotor was on the opti or should I shave the alignment groove down into a pair of teeth to simulate the regular splines and install it like the stock unit?
Thanks for any help you guys can give.
D
Old Jul 25, 2007 | 12:11 PM
If the replacement is done correctly, you don't need to make any alignment marks. In theory, there's only one way the parts will go together. Unfortunately, whether you have the spline-shaft drive unvented Opti or the dowel pin driven vented Opti, it is possible to assemble everything incorrectly. Since you are talking about shaving down the alignment groove, I'll assume you have an unvented Opti with the splined driveshaft.
Did you insure the splines were correctly aligned on both the way the shaft inserted into the back of the Opti, and the way the shaft inserted into the cam sprocket?
Old Jul 25, 2007 | 12:25 PM
Sorry, yes it is a sealed opti with the spline drive. For some reason, I can not get the spline drive out of the back of the opti. I was wondering if something was up with it or if when assembled, it was done wrong. I have literally used the robo grip pliers for the first time since I bought them 3 years ago. It won't budge.It spins fine, just won't budge coming out.
I can't be sure how it's alligned in the opti so I'm at a loss right now.
Old Jul 26, 2007 | 05:34 AM
Umm...got a dead car that I'm suppose to be driving every day. Anyone have any ideas of what's up?
Old Jul 28, 2007 | 09:33 AM
MEAN LT1's Avatar
I wish you would have called me man, I'll stop by when i get off work today.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
