smoke problem
Old Jul 20, 2007 | 10:10 PM
81z28phil's Avatar
smoke problem
my 80 Z has been sitting for about 3 years before i bought a month ago and i did a full tune up on it and its having a lot of smoke kicking out the back cant figure out wut the problem could be my uncle and i adjusted the carb and hes a master with cars so i dont think the carb is the problem he told me one thing but i was wondering if anyone had any ideas on what it could be it also has all the emissions and cat removed but i dont think that could be the cause
Old Jul 20, 2007 | 11:43 PM
angel71rs's Avatar
It can be the carb if the choke is stuck or if a piece of dirt got stuck in a float needle/seat. What color is the smoke? If it's black, carb; bluish white, oil; plain white, water.
Old Jul 21, 2007 | 11:47 AM
81z28phil's Avatar
yea its plain white and a lot of it at idle and even worse when i give it 2k rpm but what do you mean by water
Old Jul 21, 2007 | 03:23 PM
angel71rs's Avatar
If it goes away after car warms up, it's just condensation burning off. But if it's constant, it means coolant is getting into a cylinder(s). Does it seem like the coolant is disappearing with no apparant leaks? Can be a head gasket. Pull the plugs to see what they look like. Normal is light tan. If one or 2 are too clean looking, those cylinders might be where water is getting in.
If you have oily looking plugs, rings might have unseated. Oil with some miles on it will use up it's additives that are designed to buffer the acids that form as a product of internal combution and contaminate the oil. Carbed engines also contaminate the oil with unburned fuel because carbs are much less accurate at metering fuel compared to computer controlled fuel injection, especially on cold starts with the choke on. So if the engine had old oil on it when it was parked 3 years ago, that contamination has been eating at the rings, cylinders, bearings, etc.
So pull the plugs for a look (keep track of which cylinders they came out of), do a compression test and you'll have a better idea of the engine's condition.
timmy39120
May 2, 2015 05:12 PM
ad356
Apr 11, 2015 08:49 AM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
Red97LT1
Sep 7, 2002 09:29 PM
