Need some help with diagnosing a problem.
Old Jul 19, 2007 | 09:40 PM
Gripenfelter's Avatar
Out of the blue yesterday my stereo started cutting out. It does it at any volume. At first it would cut out for a few seconds and come back. Then it sometimes cut out for 2 mins and come back. Went over a speed bump today and it hasn't come on since.
Deck works. Doesn't matter if its CD or Tuner. No sound but deck equalizer display shows music flowing. Its a Kenwood deck.
I have 2 Alpine V12 amps. The subwoofer amp usually shows 14.3 volts on the display but the display is dead and shows nothing at all.
I see 12 volts on the stereo side of the main inline fuse under the hood.
At the amps I only see about 4 volts going into each of them. The remote wire shows about 3 volts.
When I turn the deck off I see 7 volts at the amps and 5 volts at the remote wire.
Old Jul 19, 2007 | 11:09 PM
PentaVolvo's Avatar
start with your grounds
when you check voltage at the amps i assume you are reading it against the grounds at the amp, which makes me assume you have a bad ground
Old Jul 20, 2007 | 12:11 AM
And right you are! It was a broken ground.
jbert55
Oct 31, 2015 03:52 PM
MDZ28
Sep 7, 2015 09:16 PM
Aug 24, 2015 06:41 AM
War Engine
Aug 21, 2015 05:28 AM
techstar
Aug 6, 2015 11:20 AM
