Injector question
Old Jul 18, 2007 | 09:59 PM
a walker's Avatar
Injector question
I found an incredible deal on a set of injectors my friend is selling, and I am curious if anybody knows if they will work for my LT1.
They are stock 39# injectors from an 03/04 Cobra. I have never seen them before, so I'm not sure if they have the proper physical dimensions and connectors.
Anybody know for sure?
Old Jul 19, 2007 | 04:42 PM
a walker's Avatar
Bump
Old Jul 19, 2007 | 08:29 PM
seawolf06's Avatar
You might try a Ford/Cobra forum.
Old Jul 19, 2007 | 08:33 PM
mdenz3's Avatar
They should fit no problem (99% sure), most domestic cars use the same style injector.
They may flow slightly more than 39# as well, Ford uses 39psi IIRC for their injector rating.
Old Jul 19, 2007 | 08:38 PM
seawolf06's Avatar
I know other Ford injectors fit the LTx and LSx motors no problem. You'll just have to correct for the different fuel pressures used.
Old Jul 19, 2007 | 09:09 PM
rskrause's Avatar
You do know you will need to reprogram your PCM, right?
Rich
Old Jul 19, 2007 | 09:14 PM
Denny McLain's Avatar
Rich
What Dude?
Old Jul 19, 2007 | 09:15 PM
rskrause's Avatar
Originally Posted by Denny McLain
What Dude?
Rich
a walker's Avatar
Thanks guys. I'm pretty sure they will work also. I asked on the Ford site I'm a regular at, but most of those guys are diehard Ford guys and didn't know.
I'm aware of the pressure difference from reading about everybody using the SVO injectors...once I get my engine together its getting dyno tuned, so I should be ok.
Thanks again for all the help. If anybody is curious, I got these for $50 and they only have 7k miles on em
Old Jul 22, 2007 | 11:25 AM
a walker's Avatar
I picked these up from my friend yesterday, and they are the correct length, but the connectors are wrong.
Anybody know where I can get injector harness adapters?
Old Jul 22, 2007 | 03:01 PM
a walker's Avatar
Nevermind, I found them at Caspers, and they're going to cost me about $100.
Guess I have some injectors for sale
Old Jul 22, 2007 | 05:26 PM
mdenz3's Avatar
Try going to a junk yard and just buying a injector harness off a mustang or something with the right connectors.
Old Jul 22, 2007 | 05:55 PM
a walker's Avatar
While that may sound like a good idea, it would require me to chop my wire harness up, which I am not willing to do.
At any rate, one of the members at the Ford site I go to alerted me to some adapters which are considerably less expensive than the Caspers. He has personally used them himself for the same reason as I need them, and they work flawlessy he says. I'll post a link in a little bit, for future reference in case anybody else runs into this problem.
Old Jul 22, 2007 | 06:27 PM
a walker's Avatar
Here's the link.
http://www.buyfordracing.com/shop/pr...roducts_id=626
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
LT14LIFE
Feb 9, 2015 09:35 PM
nophix
Nov 30, 2014 10:26 PM
