poppin fuse, non audio, but electrical
Old Jul 9, 2007 | 10:56 PM
Mischief_z28's Avatar
alright guys, got a 95 z28, and i've got the system and all that but it has nothing to do with it as tonight i've took it out and tried to narrow down the problem that has left me throwing things left and right, a fuse keeps blowing, no matter what size it is, it's the fuse right under the two silver relay looking fuses, i think it's the courtesy fuse, i cannot figure out why it keeps popping, i have a in dash tv and speakers and all but i took the deck out and it still keeps popping the fuse, so i don't think it would be that, but this is driving me insane, any help whatsoever to narrow down the problem would be nice, it wouldn't bother me because all the accesory fuse does for me is beep and turn on lights when i open my door, i could do without it, but it cuts my radio off when it blows the fuse, anyway, any help would be greatly appreciated, thanks guys.
Old Jul 9, 2007 | 11:05 PM
bmnicolosi's Avatar
you have one of 2 problems. either too much draw on that fuse, but you say when you disconnect the tv, it still does it, so i doubt its that.
or something is grounding out. It could be a bad doorpin or a bad cigar lighter, i believe the cigar lighter is tied to constant with the domelight. My dad's 95 had a problem wiht the actual lighter. pulled out the lighter while keeping the socket plugged in and the problem was gone. anyway, try that or try disconnecting each doorpin at the pin to see if it stops blowing. Dont keep uping the fuse size b/c that could cause a fire.
hope that rambling helped
Old Jul 9, 2007 | 11:08 PM
where are the door pin plugs located? if it is something grounded out, where should i start looking?
Old Jul 10, 2007 | 12:12 AM
bmnicolosi's Avatar
anywhere a screw could be touching a wire, from panels all the way up to the light. i believe the 95's had individual doorpins in each inner dorr jam, if not they are inside the door at the lock assembly.
Old Jul 10, 2007 | 08:30 AM
180 dollars to troubleshoot, fizzuk that...lol
Old Jul 11, 2007 | 08:46 AM
THE_RUCKUS's Avatar
first off, never raise the amperage of a fuse in your box. They are what they are for a reason.
Whomever installed your electronics SHOULD have properly fused them. If not, I suggest doing so. IMO that should pin-point the source of your problem.
Old Jul 11, 2007 | 01:53 PM
they are fused correctly, i think i found the problem, when i roll the dimmer switch on my headlights all the way down, it stops popping fuses, so it must be the box...what do you guys think?
Old Jul 12, 2007 | 10:14 AM
THE_RUCKUS's Avatar
trace that wire and try to find any source of a short / exposed wire
usually a quick electrical tape job will solve the problem
Old Jul 19, 2007 | 04:54 PM
found it, the light in the center console somehow shorted out, and after a nice smoke show, i found it...yeah, i'm a dumbass....lol
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
