Where is the window relay?
Old Jun 17, 2007 | 10:11 PM
DMcRacer's Avatar
Where is the power window relay for the driver side on a 96 Formula? I can hear in the dash, but couldnt find it going up through the bottom. Is it way up behind the cluster or something?
Old Jun 18, 2007 | 07:37 AM
shoebox's Avatar
What you might be hearing is the express down module. If you can hear that and the window is not working, it is usually because the window motor is bad.
Old Jun 18, 2007 | 11:30 AM
DMcRacer's Avatar
It works fine most of the time. Sometimes you let it down and it wont come back up, then out of the blue it willl start working fine again.
Old Jun 18, 2007 | 08:02 PM
custom95's Avatar
sounds more like a window motor starting to go, I've had them do that before and it finally gave out. the express down module that shoebox mentioned is kind of burried in all of the wiring to the right of the stearing column under the dash, if it's still clicking and making a weird noise then it's still good. I also made the mistake of replacing it and the window seemed to work better for awhile and then the motor died.
Old Jun 18, 2007 | 09:28 PM
shoebox's Avatar
Fairly typical symptoms of a dying window motor. You can find replacement instructions on my Tech Page.
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
