Stripped bolt in Aux Valve body, HELP!
Old May 24, 2007 | 01:28 AM
RACEON's Avatar
I was putting my aux valve body in my 93 Corvette 4L60, when the bolt (long one in picture, wouldnt even start. I took it out and the threads were gone. Then I measured the distance up to where it bottomed out and this bolt seems longer than the hole. But, it was there when I took it out as it was the one with the tab to hold the aux body hydraulic tube down.
My question is , can I tap it? Or put a slightly larger bolt in? Thnaks in Advance
Old May 24, 2007 | 06:21 AM
12SCNDZ's Avatar
The correct way to fix it would be to heli-coil it, but there's a few threads left in the bottom of the hole that MAY hold a slightly longer bolt.
Frank
CPT
Old May 24, 2007 | 01:10 PM
RACEON's Avatar
Frank
CPT
Thanks Frank. I will get a stud and see if that will work, otherwise I may helicoil it.
Old May 26, 2007 | 04:08 PM
Pete Kane's Avatar
How did you make out Steve?
Old May 28, 2007 | 12:27 AM
RACEON's Avatar
Well Pete, I put a new bolt in with a slighlty larger thread, same depth. Went quite well. Then of course you know about the 4 gear accumulator ppiston pin I found later
Yes Pete, I am all over the net when in crisis mode.
Old May 28, 2007 | 01:31 PM
Pete Kane's Avatar
I don't blame you. Lots of good info out there. This forum has quite a few good transmission guys here.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
crazypurgatory
Jan 12, 2015 10:45 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
