Gear Ratio difference
Old May 22, 2007 | 05:31 PM
95Z28LT1-PA's Avatar
What's the difference between the 3.23 and the 2.73 gears in the A4 1995 Z28? What does one do better then the other?!
Old May 22, 2007 | 05:38 PM
The rear axle ratio multiplies torque at the rear wheels, in proportion to the ratio. A 2.73 gear multiplies the driveshaft torque by 2.73, a 3.23 multiplies it by 3.23. In effect, swapping in a set of 3.23:1 gears gives you about 18% more rear wheel torque off the line.
On the other hand, at any given MPH in any given gear, the engine will be turning 18% higher RPM with the 3.23's. Its a trade-off.... more pull out of the hole, vs less MPH in each gear. Gas mileage may suffer.
Moving to "Drivetrain".
Old May 22, 2007 | 05:58 PM
LSWHO's Avatar
I doubt gas mileage changes. You need LESS throttle for the same acceleration.
My brother has 96 formula with 3.23s
I have a 97 Trans Am with 2.73s
We raced BONE stock and he'd pull like crazy from a roll and he'd pull a couple cars in the 1/4.
About 3 tenths difference in speed.
We both get the same gas mileage. I'm supposed to get better mileage, but like i said I have to press the gas more and for a longer period of time for the same acceleration. The ONLY time I'd say it would be better would be on long trips. I got 24mpg going to San Diego. He'd probably only get 23. Huge difference... yeah right.
His car pulls harder at any speed. My car feels slow as **** compared to his.
Old May 23, 2007 | 01:06 AM
Wow that much of a difference, that's crazy
Mar 13, 2016 03:39 PM
Mar 15, 2015 07:01 PM
blac94Z
Mar 6, 2015 07:55 AM
