whats up with my system
Old Nov 26, 2002 | 10:00 PM
IH8RICE's Avatar
Question whats up with my system
Allright here it goes. Im fairly new to the F-body scene as a driver and, fo damn sure a rookie when it comes to N2O. I bought my ride with a Edlebrock system allready installed. Its what i'd call a closed system with no purge valve, and its supposed to be activated by a WOT switch. Heres the dilema, when i flip the switch that supposedly arms my system the damn thing starts sprayin, not when im at WOT. Not only that but when i am at full throttle the damn thing detonates so bad it almost scares me out of using it. Any info is highly appreciated. and u might of read bout this earlier on my friends post by 95phoenix .
Deggy
Old Nov 27, 2002 | 08:39 AM
stik6shift98's Avatar
there could be a short in it... check it under the hood
Old Nov 27, 2002 | 10:03 AM
red's Avatar
red
Start by going through all the wiring and making sure it is wired through the WOT switch properly. I would also check to make sure the pills in the system are correct. If you are getting detonation you may not have enough fuel for the N2O.
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
MikeWhitener
Aug 2, 2015 06:17 PM
RUNMYTA
Jul 15, 2015 07:50 PM
