Will SB2.2 Heads woirk on L98 block?
Old May 16, 2007 | 02:48 PM
BLUETOPTA's Avatar
Will SB2.2 Heads work on L98 block?
Will the Nascar SB2.2 heads work on a L98 350 engine? If so, are they bolt on? Just add big cam and correct intake?
Thanks
Old May 18, 2007 | 11:25 AM
BLUETOPTA's Avatar
TTT, anyone? Im talking about a 5.7 L98 out of a 3rd gen
Old May 18, 2007 | 11:45 AM
N20Dave's Avatar
The short answer is yes. However, it takes custom pistons, headers and a whole lot more than just being able to bolt them on to make the motor work.
Do a search and you should find some posts about my motor.
Old May 18, 2007 | 12:05 PM
BLUETOPTA's Avatar
Why custom pistons?
Old May 18, 2007 | 12:39 PM
91Z-28's Avatar
Originally Posted by BLUETOPTA
Why custom pistons?
My guess would be
1. The valve angle of the heads
2. They have very small combustion chambers that result in very high compression since they are intended to use race gas
Old May 18, 2007 | 02:33 PM
N20Dave's Avatar
The ports are totally different than a standard head requiring a special intake manifold, pistons and headers. The cumbustion chambers are also generally in the 43-48cc range so compression will be high unless you get the pistons dished. take a look at this pic of our motor and specifically at the intake runners:
Old May 24, 2007 | 03:12 PM
rskrause's Avatar
Motor ****
Rich
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
