Whistling after Motor/pulley swap.
Old Apr 13, 2007 | 06:36 PM
BMAN'S SCZ's Avatar
Well I installed the new 383 and bumped my pulley up to 12#. After I set my Iac and tps I get a whistling sound in the throttle body (ported 52mm w/airfoil). Do any of you guys have this problem? I think it is the blades but all my values are good. I only get it at about 1500-3000rpms. It gets kinda of annoying. I thought it might be from the smaller blower pulley. What do all you guys have your values set at? Any info would be great, Thanks...John
Old Apr 13, 2007 | 06:59 PM
VK's Avatar
VK
I have the same problem, but its from my BOV. I don't have any BPV.. so the BOV somehow makes a whistle, put my hand infront of it and whistle goes away.
Old Apr 13, 2007 | 07:05 PM
BMAN'S SCZ's Avatar
Ya, I have BPV. I'll try to check it some how. It doesn't whistling in park revving it, only driving down the street. My kit was for 8# originally, do you have to change the spring when you increase pressure? Thanks for the advice though......John
Old Apr 13, 2007 | 07:14 PM
VK's Avatar
VK
If you have the small BPV that comes with the kit, you may need to upgrade to a larger one. When you increase the blower output you need to dump even more extra boost when your not hammering on it. So when you cruising ~2,000rpms the blower is pushing out alot more then before, it is having a hard time getting out the small BPV so its causing a whistle sound. Put a strip of tape across the opening, you should be able to tell if its coming from the BPV then. You'll need to upgrade if its the case.
Old Apr 13, 2007 | 07:20 PM
BMAN'S SCZ's Avatar
I will certainly look at this. Thanks again....John
Boss002
Jul 24, 2015 10:47 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
1st and goal
New England Area
46
Jun 8, 2003 05:49 AM
OffspringZ28
Feb 25, 2003 09:22 PM
2001CamaroGuy
Jun 24, 2002 01:29 AM
