Question about OBD I and II
Old Apr 4, 2007 | 04:50 PM
crucescamaro's Avatar
I have a 95 camaro that has the OBDII plug. The posts i've read say the 95's are still OBD I. Can you use the OBDII scanners that are available to read codes and monitor engine stats?
Old Apr 4, 2007 | 05:09 PM
2001NBMZ28's Avatar
My buddy has a '95. It's OBDI with an OBDII 16 pin DLC also. You need an OBDI scanner with a cable that'll connect to the DLC, or jumper the pins between the scanner/DLC.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
