injectors
Old Mar 26, 2007 | 10:46 AM
96camaroz281988's Avatar
injectors
do any of the LS engine injectors work on the LT1
Old Mar 26, 2007 | 11:36 AM
2000GTP's Avatar
The stock LS1 injectors would flow about the same on the stock lower fuel pressure of the LT1.
Old Mar 26, 2007 | 12:03 PM
why i am asking this is that i have some 26 lb injectors frome a corvette i was wanting to no if they would work on the LT 1
Old Mar 26, 2007 | 05:36 PM
The LS1 injectors are flow rated at 58psi, and the LT1 injectors at 43.5psi. That means that if you run a 26 #/HR LS1 injector in a lower pressure LT1 fuel system, is will only flow 22.5 #/HR. They will fit into the LT1, but you would either need to raise the fuel pressure to get them back to the stock injector rating (24.9 #/HR) or have your PCM programmed with the smaller injector size.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
