1/8" npt distribution block
Old Mar 22, 2007 | 01:04 AM
69gto96z's Avatar
Does anyone make an 1/8" npt distribution block, that has a male on one end to screw into the bottle, and 2 females on the other end? I want to screw my gauge and my bottle warmer switch both into the bottle, but only have one spot to do so.
Old Mar 22, 2007 | 09:29 AM
Ray@NitroDaves's Avatar
Black
http://www.nitrousoutlet.com/catalog...roduct_id=2697
Blue
http://www.nitrousoutlet.com/catalog...product_id=368
Old Mar 22, 2007 | 10:00 AM
69gto96z's Avatar
Isn't the fittin on the bottle an 1/8" NPT fitting? I am wanting to put something in the female fitting on the bottle where the gauge mounts, that way I can have 2 things there instead of just one, and so I can see bottle pressure and use the automatic warmer switch all the time instead of just when the bottle is open.
Old Mar 22, 2007 | 10:36 AM
misread the OP.....
to fab it the way you are describing you will need:
1/8nptX1/8npt union
http://www.nitrousoutlet.com/catalog...product_id=956
Distribution block
this one is a 1 in 3 out...cheapest one we have
http://www.nitrousoutlet.com/catalog...roduct_id=1143
and a 1/8 npt plug for the unused hole
http://www.nitrousoutlet.com/catalog...roduct_id=2712
or you could replace the whole valve...my reccomendation
http://www.nitrousoutlet.com/catalog...roduct_id=2148
our valve comes with 2 ports built into the valve body
Old Mar 22, 2007 | 10:45 AM
69gto96z's Avatar
I think I might just do that. If I ordered it before noon, when is the earliest it could get here by?
Old Mar 22, 2007 | 11:07 AM
ship today you will have it tommorrow using UPS ground
if you are going to order online make sure that your current bottle uses the 2 piece bottle nut/nipple if your uses the 1 piece (660 style) you will need a 326 style bottle nut and nipple
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
maverickmk
Sep 1, 2015 09:17 PM
