Battery relocation
Old Nov 23, 2002 | 09:25 AM
Kyle@CSS's Avatar
Battery relocation
I got the box and the wire. I was wondering hows the best way to hook this up. Any links would be helpfull
r/t .622
60' 1.65
330 4.685
1/8 7.190
mph 98.39
1000 9.343
1/4 11.167
mph 122.69
South Carolina F&Y bodies
www.scfyb.com
Old Nov 23, 2002 | 07:06 PM
The January 2003 issue of GM High-Tech Performance magazine has a detailed article on battery relocation.
Old Nov 24, 2002 | 03:12 PM
Projectz28's Avatar
I was just going to say the same thing as Fred. The Jan issue has a detailed article on how to do it.
Old Nov 24, 2002 | 05:41 PM
kazman's Avatar
The only thing that I don't like is the battery placement. My car has t-tops and the battery relocation goes right where the tops are stored. BMR makes a bracket that mounts in the spare tire location. The BMR kit is not a battery box just a hold down bracket which will not pass tech. Over winter I'm gona try to relocate the battery in an enclosed case using the BMR bracket. I still would like to be able to drive the car on the street with the tops off. The more I race the less the car is on the street.
Old Nov 26, 2002 | 07:59 AM
N20Dave's Avatar
The GMHTP article is good but it does not mention anything about how to wire the system to shut down the electrical system/alternator as mandated by NHRA rules. Anyone have any thoughts or links on that?
Old Nov 26, 2002 | 08:08 AM
Brady's Avatar
A fellow Board Member "Steve10" sells some pretty cool stuff, including a battery disconnect switch.
Check it out at: http://www.mycamaroz28.homestead.com/
Old Nov 26, 2002 | 08:24 PM
matt95z28's Avatar
Does battery relocation make a big difference?
Old Nov 27, 2002 | 08:43 PM
kirschman's Avatar
http://flamingriver.com/enter.htm Give these peeps a try on the disconnect switch, looks pretty trick to me. I ordered mine from a local parts store for around 90 bucks. And yes it does help, weight transfer, and of course make the engine bay look alot better!!
edit; scroll down to the battery switches and click on the racing one, its at the bottom of the page.
Old Nov 28, 2002 | 06:42 PM
1fastV6's Avatar
the 2003 issue?
Old Nov 28, 2002 | 11:01 PM
Originally posted by 1fastV6
the 2003 issue?
Yes. The issue with the feature article about the "Eleven LT1 Bolt-On Cars That Haul".... many of them from this board.
Are you not aware that many magazines are post-dated by several months? I received the January 2003 issue (Volume 9, No. 1) at least three weeks ago...........
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
weedog
Aug 15, 2015 08:23 PM
