SLP Fan Switch Control...
Old Mar 9, 2007 | 02:23 PM
krazykorean35's Avatar
anybody out there have this installed on their car...does it really make a difference...already have a slp160 thermostat installed??
Old Mar 9, 2007 | 02:35 PM
69gto96z's Avatar
Its not worth the money. 10 ft of wire and a switch from radio shack is all you need. I just spliced mine into the ground side of the high speed fan relay coming out of the under-hood fuse box and grounded the other side of the switch. When I flip the switch, the fans turn on. Works perfect, and cost about 4 bucks.
Old Mar 9, 2007 | 03:01 PM
do ur fans still turn on automatically?
Old Mar 9, 2007 | 03:17 PM
2001NBMZ28's Avatar
Don't know what the going price is nowadays, but put one in my car years ago and never had a problem with it.
Old Mar 9, 2007 | 04:34 PM
LBJ's Avatar
LBJ
Yes...
I have the SLP version, it has been on the car for 2-3yrs and works great. It works great when you are stuck in a slow moving staging lane...you can flip it on the High setting and it will keep the water temp from climbing.
Old Mar 15, 2007 | 06:41 PM
Zitty'sZ's Avatar
When you turn the fans to high speed , do both fans blow air? The reason that I'm asking is because when I have the switch on low I can feel the air blowing from both fans, but when I switch to high, only the passenger side fan seems to be working. Is this normal?
Old Mar 15, 2007 | 06:51 PM
2001NBMZ28's Avatar
Using the switch both of my fans run, regardless of speed setting.
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
MYT30TH
Jul 28, 2002 08:47 AM
