So how common is it for LS1 calipers to seize?
Old Mar 5, 2007 | 01:17 PM
CamaroCasanova's Avatar
My new to me 99 WS6 car had 1 seized caliper floater bolt on each side. I heated them out and got new ones, (and installed new rotors/pads) which fixed the vibration-it is impossible to get new brackets (even used ones hard to find) so I am wondering why auto parts stores only sell the caliper itself if this is a common problem?
Old Mar 5, 2007 | 01:21 PM
justav6iswear's Avatar
I work at a parts store, never sold one of those or even thought about it. I looked through our catologs and I dont even think I can get one without trying some crazy special order deal. Lube the hell out of it with brake lube/antisieze when your throwin it back together, sounds like a bad install last time.
Old Mar 5, 2007 | 04:24 PM
Yeah that is exactly what I did-I just wondered if it is something that is common or not since both were screwed up, and they are not easy to find in junkyards (not pick n pull type-the expensive they pull it ones) either. The car came from a very wet environment in San Francisco bay area from an owner that had no clue about cars so it must have been poor work by a mechanic and/or the environment.
Old Mar 5, 2007 | 10:35 PM
touch109's Avatar
if your looking just for the caliper bracket you have to go to the dealer and order it.. i have a spare but the bolt is stuck to the bracket..
Old Mar 6, 2007 | 07:33 AM
2000GTP's Avatar
Its not a common problem, I definitely believe that as mentioned above, the previous install was done incorrectly. Those pins need to be lubed up well before being put back in and it doesn't hurt to check them every so often.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
