stock LT1 replacement brakes
Old Mar 3, 2007 | 10:39 PM
maro z28's Avatar
How much do they typically run and where can I find them? I'm looking for everything, i.e. rotors, calipers, pads, even spindles.
Old Mar 3, 2007 | 10:44 PM
OBE1 95Z28's Avatar
I wouldn't spend the money to buy new stock LT1 brake setup. For the same or slightly more money you could with the LS1 setup which is a much better system (1" diameter large rotors, dual piston calpiers). Do a search on the LS1 brake conversion.
If you really want the LT1 setup, there's probably a lot of used parts out there to be had cheap.
Old Mar 3, 2007 | 11:24 PM
maro z28's Avatar
The brakes are so I can run Bogart wheels. Will LS1 brakes fit w/ Bogarts?
Old Mar 5, 2007 | 11:52 PM
blackztpi's Avatar
yes...whatever you do, don't buy cheap pads. the pads make the brake obviously. i had a set of duralast's and if you stepped on the brakes twice in a row they would hardly stop and when you did it would be a stink smoke fest
Old Mar 6, 2007 | 07:38 AM
2000GTP's Avatar
I definitely wouldn't step down in braking ability. Could you contact Bogart first to make sure their wheels will work around your application? If you do go with the LT1s, people are practically handing them out. When I finally get around to installing my LS1 set, my LT1s will be going to the curb for garbage pickup I'm sure.
Old Mar 6, 2007 | 09:57 AM
maro z28's Avatar
Dude send me a pm before you do that. You could sell em to me and at least make something.
Old Mar 7, 2007 | 12:34 PM
The Captain's Avatar
I just bought pads for the rear (lifetime warranty) and one rotor cost me $40
Old Mar 7, 2007 | 01:36 PM
Z95m6's Avatar
I believe I have my complete old LT1 stuff minus one of the hubs but they're interchangeable between LS1 stuff. The shipping is what would kill you.
ddr698
Jan 9, 2015 10:05 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
vals95z
Mar 18, 2003 03:45 PM
GigaMp3z
Feb 20, 2003 02:57 PM
mjcent922
Jul 27, 2002 12:42 PM
