Custom one off 3rd gen aftermarket gauge cluster. Pics inside.
Old Feb 24, 2007 | 08:58 PM
oneslowz28's Avatar
Me and my friend charlie (stangkilla91) spent all yesterdsay and today buying the stuff and fabbing up this custom gauge cluster for charlies thirdgen. We used 1/4" aluminum plate stock and cut it to size. Then we used a 3" hole saw and a 2" hole saw to cut the rough holes. Final touches to the holes were made with a dremel using a carbide bit. The leds came from radioshack and were wired with 640 ohm resistors and placed in a chrome led holder. The switch panel goes inside the console. The switch panel uses the same typ leds and resistors and led holders. The switches are just plain toggel switches. The gauges are Auto Meter's Phantom II series. The gauges in the cluster are: Speedo, Volt, fuel level. The ones in the pillar are oil pressure, tranny temp and water temp. The tach is a shift light/digital tach by autometer.
cluster layout
final layout
drilling the holes
almost there
switch panel layout
Me touching up the gauge holes with the dremel.
Beginning to powder coat the panels and my 5 point harness buckels
More powder coating
Even more powder coating
Old Feb 24, 2007 | 08:59 PM
oneslowz28's Avatar
Continued.
Switches and leds
Finished cluster panel
Cluster panel lit up
More cluster panel
switch panel
Tripple pillar pod and gauges
Auto meter Digital tach/shiftlight combo unit
Old Feb 25, 2007 | 10:36 AM
Caps94ZODG's Avatar
Looks good man just need to see it installed. To tell you how it looks fit inside the car.
Old Feb 25, 2007 | 04:50 PM
convertz's Avatar
Whats the row of yellow and red LED's for?
Old Feb 25, 2007 | 05:45 PM
Brangeta's Avatar
I've never liked custom stuff like that in cars, but I respect the hard work you put into it. It looks very good!
Old Feb 26, 2007 | 04:19 PM
78Z28350's Avatar
nice! very clean looking and looks like a race car. im assuming the 2 green LEDs are the left and right turn signal and the blue is high beams on? but im wondering what the yellow and red ones are also?
and i gotta see that in the car in day.
Old Feb 26, 2007 | 04:34 PM
oneslowz28's Avatar
Yellow 1 = fans on
Yellow 2 = electric water pump on
Yellow 3 = line lock
Red 1 = check engine light
Red 2 = low oil light
Green 1 = l turn
blue= high beams
green 2 = R turn
Old Feb 26, 2007 | 04:38 PM
78Z28350's Avatar
Originally Posted by oneslowz28
Green 1 = l turn
blue= high beams
green 2 = R turn
ahhh see how good i am
and is his car pro street or somethin with all this line lock and shift light mombo jumbo? i gotta see more of this thing
Old Feb 26, 2007 | 05:27 PM
oneslowz28's Avatar
We both just run on the tnt and gamblers nights. No classes yet. But we did swap a lt1 into it.
Old Feb 26, 2007 | 08:18 PM
stangkilla91's Avatar
ill definately post pics of it when im through, hopefully it will be soon, but who knows, these things seem to take longer to finish than expected. like jeff said, i just run at t&t nights for fun, but plan on getting into a class when i get it back on the road. thanks for the support guys.
Old Feb 26, 2007 | 09:15 PM
78Z28350's Avatar
yeah i gotta see how it looks in the dash and where the switch panel goes where are you putting the switch panel anyway?
Old Feb 26, 2007 | 09:25 PM
shock6906's Avatar
So who owns the powder coat setup?
Old Feb 26, 2007 | 11:21 PM
oneslowz28's Avatar
the switch panel fits into the console box.
That would be charlie
F'n1996Z28SS
Aug 23, 2023 11:19 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
rwferguson43026
Feb 6, 2015 10:06 AM
ddr698
Jan 31, 2015 10:58 AM
5.7L 00 SS
Aug 6, 2002 07:01 AM
