LE2 LT1 with 75-125 shot. Do I have to change plugs?
I was thinking about adding some laughing gas, but dont know if Im 100% sure on that.
I was wondering if I do not change my plugs (I currently have the ones that Lloyd recommends for the LE2 setup) will it be alright for a 75 shot?
And which one would be safer in that application? Wet or dry? I have 42lb injectors in there currently.
I would go with a wet kit, and NGK TR6 plugs. They are a step colder to help keep you from detonating. Also, if you dont already, I would get a new ignition system, such as the mallory 685. That way you can retard timing and have a window switch for the nitrous. BTW, your formula is AWESOME! You got any sound clips?
I agree, talk to Lloyd again, he will be your best source for finding out what you may need.
I asked the same question to Lloyd just a couple of weeks ago about my LE2 combination. Here is his response, word for word:
"The 5671A-7 plugs will work on NOS but if going over a 200-250 shot a colder plug (-8 or -9) might be even better. These colder plugs WILL fail faster when running N/A though."
The NGK plug he mentioned is what he recommeded for my LE2 combo for NA. You will have to close the plug gaps to somewhere around 0.032" or so to run Nitrous. I agree that a wet kit is a better choice for an LT1.
