No sound at all after new cd player install...
Old Feb 15, 2007 | 09:21 PM
Whitey13's Avatar
I put in an aftermarket Pioneer and everything works right except I have no sound at all from any speaker in the car. 1994 Camaro Z28 with factory Bose. I've checked all the wires to make sure I have them spliced right and they are. Any ideas?
Old Feb 15, 2007 | 09:36 PM
Whitey13's Avatar
I'm gonna need to hook up the remote wire because of the stock amp in the car correct? Pfft, my bad. I should have thought of that before...
Old Feb 16, 2007 | 12:06 AM
fredmr39's Avatar
I believe this relates to the setup you have in your car:
http://web.camaross.com/forums/showthread.php?t=500925
EDIT:
Old Feb 16, 2007 | 12:37 PM
valter's Avatar
Yep, if I remember correctly it should be pink. Bose will work without any adapter with aftermarket HU, people running like that for years, however it is not recommended - you can fry your HU due to overloading.
Old Feb 18, 2007 | 06:05 PM
blunto's Avatar
What is the "remote wire"?
Old Feb 19, 2007 | 01:43 AM
benhart21's Avatar
Remote wire is a blue wire coming off the harness from the h/u that sends a signal for whatever amplifier it's connected to for it to power on.
Old Feb 19, 2007 | 05:26 AM
KyleBlue85Iroc-Z's Avatar
Hooking up the remote wire/ant. wire to the jumper for the bose amp will work.
BUT...you're WAY overpowering your system that way. I did this in my car for about a month and I had very little volume control. My volume goes from 1 to like 40 on my alpine HU, and when hooking it up this way I drove around with it no higher than 4 or 5. Will easily blow the speakers this way, too.
Good luck.
Old Feb 19, 2007 | 09:09 AM
PentaVolvo's Avatar
the easy fix for this especially if you have a headunit with higher voltage preouts is to splice rca connectors onto the speaker wires coming from the car harness and plug them into the appropriate rca jack on the radio... if i am unclear on how this is done i can specify more
Old Feb 19, 2007 | 03:14 PM
That actually sounds like a good idea. Have you done this personally?
Old Feb 20, 2007 | 12:01 AM
PentaVolvo's Avatar
yes I have on a number of bose cars, alot of bose camaros and mid 90s nissans, always works great. Sometimes if you have low voltage preouts or a crappy radio there just wont be enough power out of the preouts and you will max the volume **** and the speakers wont be breaking up. Generally speaking this works great I used to do it all the time
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
