NX intake, NXL DP system, 85mm TB
Old Feb 13, 2007 | 09:53 PM
mrr23's Avatar
just got it in today. normally, this kit would have nozzles that go under the fuel injector. i got their LS intake that has the ports drilled into the intake for the nitrous and fuel.
the intake
here's a close up of where the nitrous lines will go to just like if you had a nozzle.
here's what it looks like inside the injector hole where the nitrous and fuel will come out
the underside of the intake has a 1/4" thick aluminum plate
inside the intake
the NXL direct port kit replaces the factory LS intake fuel rails. this way, it pulls fuel right off the rails
the fuel accumulator. this helps with the initial hit of the system.
Old Feb 13, 2007 | 09:58 PM
mrr23's Avatar
the 85mm TB
Old Feb 14, 2007 | 08:49 AM
2000GTP's Avatar
That is a beautiful setup, how much does it retail for?
Old Feb 14, 2007 | 10:35 AM
Rice Killer87's Avatar
Sweet lookin man,good luck on getting it together.
Old Feb 14, 2007 | 11:57 AM
Nitro Dave's Avatar
Sweet, Thats is going to make one sweet looking set up..
Dave
Old Feb 14, 2007 | 07:48 PM
mrr23's Avatar
Old Feb 14, 2007 | 07:49 PM
mrr23's Avatar
intake 850
tb 525
NXL 1200
accumulator 200
total 2725.00
technically, the NXL DP system is less if you have the intake as you won't need the NXL nozzles that would normally go under the injectors.
Old Feb 14, 2007 | 09:56 PM
Bandit 1's Avatar
thats beautiful, and a lot of money
Old Feb 15, 2007 | 01:45 PM
2000GTP's Avatar
Originally Posted by mrr23
intake 850
tb 525
NXL 1200
accumulator 200
total 2725.00
Definitely a pricey setup, but it looks like it is going to turn out nice. Didn't you have a dual stage nozzle setup before? What are your goals with this new nitrous setup?
Old Feb 15, 2007 | 06:27 PM
mrr23's Avatar
i still currently have the two stage n2o. haven't gotten the 100/150 shot working out past 1/8 mile. the 11.262 @ 122.78 ran was on a straight 200 shot coming on at 2700 rpms.
with the motor this setup is going on, it will be 9s capable. car itself won't be, but the motor will be. mid to low 10s, i'll be fine with.
Old Feb 15, 2007 | 06:33 PM
2000GTP's Avatar
How high of a shot are you going to go with this new setup?
Old Feb 15, 2007 | 06:36 PM
mrr23's Avatar
set on stun at 180 rwhp. i'll still have a single nozzle for some added power. i'll need to set it on a stand alone though.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
CARiD
Jan 27, 2015 06:27 AM
