Pacesetter LTs and ORY with cats???
Old Feb 12, 2007 | 03:01 PM
khojo16's Avatar
right now i have stock manifolds, stock y pipe, and SLP Loudmouth catback...i am buying pacesetter coated LTs with emissions, and pacesetter y-pipe....is there any easy way to make this setup work with cats bc I live in NJ and they are tough on emissions...one cat after the y-pipe, or two cats within it works as long as it works for emissions...also if anyone has done this please let me know what you did and any pics are very appreciated. thanks in advance
Old Feb 12, 2007 | 03:03 PM
2000GTP's Avatar
I had a pair of Pypes mini-cats welded into the y-pipe. You will still need a pair of 02 sims or PCM tuning to remove the rear 02 codes.
Old Feb 12, 2007 | 03:07 PM
khojo16's Avatar
pcm is already tuned with rear O2's removed...and i saw the Pypes mini-cats...they work well being welded in the y-pipe???...also is there anything else i would need???
Old Feb 12, 2007 | 03:09 PM
95LT1conv's Avatar
damn, you always seem to beat to these posts.
what he said.
Old Feb 12, 2007 | 03:11 PM
2000GTP's Avatar
Yes, they fit like a perfect sized glove. The drivers side is the trickiest, that is where a dimensionally smaller cat is needed because of the fuel/brake lines and the torque arm. On the passenger side, there is gobs of room so it is a non-issue. Long story short, they work great and are a good quality converter.
Old Feb 12, 2007 | 03:41 PM
khojo16's Avatar
you got the 3" model Pypes cats right?? and also do you have pics of ur y-pipe with the cats welded in?? bc i wanna see how far up on the driver's side the cat has to be placed?? thanks for the quick responses and great info so far!!
Old Feb 12, 2007 | 03:46 PM
CreatiVe2's Avatar
good Bolts, gaskets, copper RTV, good exhaust shop (for cat work), oh and at least 2 days of your life, and while your at it, you might need to replace your hands once your done... have fun on the passenger size couz.. heh...make sure they are coated!!!
Old Feb 12, 2007 | 03:51 PM
2000GTP's Avatar
Yes, I have the 3" Pypes cats, but sorry, I do not have pics of my setup. The passenger side cat is right at the tail end of the header. The drivers side is spaced about a foot away from the header due to the various junk in the way. Do a search or PM 96Flame, he had a dual cat y-pipe similar to mine and he had pictures. That will give you an idea of how far away the drivers side cat is spaced.
Old Feb 12, 2007 | 04:01 PM
khojo16's Avatar
thanks for all the great info 2000GTP
and jared (Creative2)...since your my cousin...and my bday is like next week...wanna help me with the install??? lol and yes they are coated...
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
