Turn signal lever issue
Old Feb 12, 2007 | 12:15 AM
tom3's Avatar
Suddenly, the signal level started to not disengage when I turn the steering wheel back straight. It works on one end, but not the other side :s
I know the bulb has gone bad too, but I assumed the lever mechanism was purely mechanical.
Has anyone ever experienced this? also, is the lever assembly one piece you swap, or is it something you can actually open and service?
Old Feb 12, 2007 | 10:48 AM
2000GTP's Avatar
It sounds like the turn signal assembly is going bad and is something that can be swapped for a new one.
Old Feb 12, 2007 | 11:05 AM
Sinister_Z's Avatar
Sounds like one of the turn signal cancel springs are broken...you can replace the springs for a couple of dollars...I would do both of them while you are in there for the price of them...
Old Dec 14, 2007 | 06:16 PM
Detroit808's Avatar
I have to bump this thread because I have the same problem. My turn signal lever won't return to the original position when you signal left. Please keep in mind that I have no experience with the steering column whatsoever. What parts do I need to replace? Also, does anyone have any pictures or procedures on how to do this?
Old Dec 15, 2007 | 11:22 PM
Fatdog2's Avatar
Be sure to disengage,or disable the air bag before going in there.Might do a lot of damage to you,and,the cost of a new air bag.Hope this helps.
Old Dec 17, 2007 | 09:04 AM
SNOTGREEN's Avatar
lol, I have a similar problem with that arm, except for me, if I click my bright lights on, they don't want to click back to normal beam. Anyone else?
Old Dec 17, 2007 | 10:38 PM
acre's Avatar
I had a similar dimmer switch problem
I thought the problem was in the lever, but the dimmer switch for the high beams is actually on the column down near the pedals, and is actuated with a push rod from the signal lever. My problem was because the push rod wasn't pushing the switch all the way down. Use the info here (thanks Shoebox!) and remove the panels below the steering column to get at the switch and push it by hand to see if the switch is bad or if its the push rod.
To fix mine, I pulled the push rod out of the switch and cut off a short piece of a bolt that was the same diameter as the push rod and put this in the switch prior to putting the push rod back in. I know kinda a cheesy way to fix it, but I didn't feel like taking the whole column out to get at the screws to adjust the switch.
If the switch is bad you are probably going to have to pull the column to replace it, and the rest of the like above tells you how to do that. Although if its not the push rod it could be something besides the switch...
I hope this helps... this is my first post
Old Dec 19, 2007 | 04:09 PM
NEWBIE T/A's Avatar
Lightbulb There is probably a newer write up somewhere, but ...
This will serve as a good start .
You can see the springs - or where they should be - here.
The whole thread is here.
It's failry straightforward if you understand how it works ,and can lay your hands on some of the special tools - like a wheel puller & lock plate puller.
Otherwise, it's a masive bee-yotch, and you could damage the column .
Hope this helps !
Britt
Old Dec 27, 2007 | 07:34 PM
texz's Avatar
Mine does the same thing, only on left turns. I would try to fix it, but being that close to the airbag...
Old Jan 4, 2008 | 05:21 PM
SNOTGREEN's Avatar
I gotta agree, if I was gonna go through all that trouble, I'd just pull the column as shown, and install a grant wheel or something while I'm at it. Thanks for the info guys.
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
