TB or TB boot for nitrous jet?
Old Feb 11, 2007 | 05:39 PM
Gtpguy's Avatar
I'm 99% sure I've found the car I'll be buying this week. It's a 1996 6spd WS6. It has Nitrous on it though and the jet is in the TB boot. Now, the way it's sitting the Jet is spraying away from the TB towards the front driver side wheel instead of straingt into the TB itself. So the owner says the jet will probably only go into the driver side cylinders as it's sucked in. I'm not a physics major so I just went with it.
Now, on my brothers GTP he drilled a hole in his TB and mounted his Nitrous nozzle into that. Can I do that, or is there a special boot that I can buy that will make the nozzle sit in the right position?
Thanks.
Old Feb 11, 2007 | 05:51 PM
my94blackz's Avatar
90 bux for a ceramic coated elbow, and it will be mouted solid. Heres a bad pic of mine why I was doing some spring cleaning
Old Feb 11, 2007 | 06:49 PM
2000GTP's Avatar
If it is the NX shark nozzle you can try using the adapter (NX-15719) http://www.nitrousoutlet.com/catalog...del=88&dept=11 That should give it a more secure fit in the intake elbow where it points in the correct direction.
Old Feb 11, 2007 | 07:19 PM
Gtpguy's Avatar
My94blackz, the car is a Ram Air Trans Am so I can't use the elbow.
Old Feb 11, 2007 | 07:38 PM
Z-RATED94's Avatar
Why not get a hold of one of our sponsors and ask them what they think would be the right way for your car?
Old Feb 11, 2007 | 11:28 PM
Posting on the N2O Tech forum would have probably got you a direct response from one of our Supporting Vendors.
Moving to N2O Tech
GREEN3112
Feb 10, 2019 09:19 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
Devinfoote87
Jul 30, 2015 09:54 AM
jbc3
Jul 28, 2015 12:24 PM
