Lots of hi-po parts for sale
Old Nov 20, 2002 | 06:39 PM
squinn's Avatar
Post Lots of hi-po parts for sale
Set of 8 bosch 36 lbs injectors $225 obo
J&S Electronics Safeguard with Knock Monitor, works on LT1 or any std V8.
Would be great for SC or turbo motor on pump gas $325 obo
Edelbrock Vic jr intake setup for LT1 heads for carb setup, $175 obo
JW SFI flexplate for 87 and up SBC $60 obo
4.10 gears for 9" Ford $50 obo
Comp Cams Pro-Magnum Non-Self-Aligning Roller Rocker Arms, 7/16" stud, 1.6 Ratio, guide plates, 7/16 studs $200 obo
Detroit soft locker for 31sp 9" Ford $275 obo
2 LT1 2-bolt blocks, one is a stock short block with some spun rods $150 obo
2nd one a bare block that needs a .040 over bore, its drilled for 4 bolt main, no caps $150 obo
Cam motion hyd roller 242/251 584/592 w/1.6 rr on a 108 lc made 560 engine HP @ 7000rpm with my stock short block 350 and lt1 heads, best et was 10.54@127, best mph was a 10.59 @ 129.
I'm selling cam, Cran hyd roller lifter, AFR hdydr rev kit and valve springs for $450
MSD 6A box $60
4 - 97' Z28 16" 5 spoke wheels, silver in color, very low miles, mint $180 obo
2 - BFG comp TA ZR 245/50/16 tires with 85% tred left $100 obo
Alum tubing 2- 90* 4" 6061 bends and 3 ft of 4" tubing $75 obo
17 Smith bros push rods with 210*b for T&D rockers 7.035 long 5/16 .084 wall, 10 pass on them, new $170, selling for $80 obo
16 pushrods 5/16 .084 wall 7.155 long $50 obo
Old Nov 20, 2002 | 06:58 PM
dreamer1q's Avatar
How many miles and condition of the injectors...please
Old Nov 20, 2002 | 07:19 PM
squinn's Avatar
No miles only used at the drag strip, about 10 passes.
these are the bosch silm line injector.
Old Nov 20, 2002 | 08:17 PM
dreamer1q's Avatar
They will fit in my stock LT1 fuel rails and work?
Old Nov 20, 2002 | 09:11 PM
squinn's Avatar
yes they will work in your stock lt1 fuel rail, also your PCM will have to be reprogram so they will work.
Old Nov 21, 2002 | 05:56 AM
dreamer1q's Avatar
Yeah, my PCM has more to change then just the injectors this year That is not a problem. Let me see if I can get the money out of the warden...un I mean wife
Old Nov 21, 2002 | 10:06 AM
cASe SenSiTive's Avatar
Exposed Member
You've got mail.
Old Nov 22, 2002 | 08:50 AM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
is shipping included on the msd6a box?
if so consider it sold
Old Nov 22, 2002 | 07:45 PM
Victory Racing's Avatar
I'm interested in the 9" gear set Steve.
If you haven't moved it yet, consider it gone.
Old Nov 23, 2002 | 05:40 PM
BLU98Z28's Avatar
I would be interested in the tires if you will deliver them to the downriver area. Or maybe we could meet 1/2 way. You can call me on my cell at (734)658-0250 And let me know the deal.
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
00WS6mike
Sep 13, 2002 10:37 PM
Carguy00
Aug 6, 2002 10:25 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
