O2 extention for lt1?
Old Jan 21, 2007 | 01:31 PM
toolmaker's Avatar
How long of extention do you need with pace long tube headers on a lt1???
THANKS
Old Jan 21, 2007 | 01:49 PM
69z-28's Avatar
with my hookers which i would assume have pretty similar O2 locations as the pacesetters, i got the 12" ones then realized they wouldnt be long enough so i got the 24" ones. they leave you lots of room to work with, i had to tie them up in a few spots to make sure they didnt touch the headers or anything they shouldnt have. i would go with the longer ones instead of fighting with the shorties to reach
Old Jan 21, 2007 | 03:21 PM
2000GTP's Avatar
I originally bought the 24" extensions for my Pacesetters and I was just unhappy with how much extra length I had in the harness. I ended up buying a pair of 12" extensions and swapped them out. They were perfectly long enough for my application.
Old Jan 22, 2007 | 03:36 PM
toolmaker's Avatar
Thanks
Old Jan 24, 2007 | 09:38 PM
69z-28's Avatar
hmmm. too short for my hookers. maybe they are different for Pacesetters.
Old Jan 25, 2007 | 11:42 AM
2000GTP's Avatar
I believe the 02 bungs are in different locations between the two brands so that may be why.
Old Jan 26, 2007 | 01:15 AM
ponyackn's Avatar
I too found that the 12" extensions were good enough with my pace setters.
Old Jan 26, 2007 | 03:30 PM
toolmaker's Avatar
do you all have single wire O2's or multiple wire O2's???
Old Jan 26, 2007 | 03:41 PM
2000GTP's Avatar
4-wire O2s.
Old Jan 26, 2007 | 06:46 PM
toolmaker's Avatar
that's why I can't find the right O2 ext. mine is a single wire.
Old Jan 26, 2007 | 06:59 PM
2000GTP's Avatar
Your options may be limited then, I'm only seeing 24" extensions for the single wire sensors. Not a big deal though.
Old Jan 27, 2007 | 06:24 PM
toolmaker's Avatar
where did you find the single wire ext. at????
Old Jan 28, 2007 | 12:22 PM
2000GTP's Avatar
Thunder Racing.
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
redzed
Sep 4, 2002 06:22 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
99BackNBlackZ28
Feb 26, 2002 03:46 PM
