remove factory guages and install aftermarket?
I'm looking for some ideas on how to set up my guages.
I bought an old stock guage cluster and dissasembled it. I have already cut it out and all I need is some abs sheet plastic to put in there. I am planning on installing some of my Autometer guages in the stock dash via the stock cluster.
Has anyone else done this? I am looking for some pics to give me some ideas on how to set mine up. I am trying to fit several guages in there
water temp, trans temp, oil temp, fuel pressure, vacum, oil pressure, and battery volts.... all are electric except the vac. which is mechanical. All are 2 1/6" and I would like to put them all in the dash.
Anyone got any pics of custom set up's?
yes I will be doing an aftermarket tach but that will go on top of the dash or mounted to the pillar. I'm reusing my old 3 1/2" Autometer streert tach which will runn off of my MSD. No speedo... its a race car, I only care about rpm
Thanks for the cardboard idea. I didnt want to go cutting the abs and find out I dont like it when I am done.
I think the other hard part will be cutting out all the factory wiring to the guage cluster. Most of teh factory wiring has already been trimmed of what I dont need. This guage idea just popped into my head about a month ago.
. Thanks for the cardboard idea. I didnt want to go cutting the abs and find out I dont like it when I am done.
no one has any pics on this!!?
I am very interested in this as well!
Projectz28 could you elaborate a little more on what you have removed so far?
I have good wiring skills but am a little leary at the mass behind the dash!
email is ld_patterson@yahoo.com
Thanks
Thanks
hotrodyou1
Dec 20, 2014 10:05 PM
