What gears do i need ? for 1/4
Old Jan 5, 2007 | 11:56 PM
Schurters LT1's Avatar
Hey Guys,
not to sure on what gear i should put in the car ??
Car is an M6
28" tire
3800lbs with me in it
close to 700rwhp
7000rpm
i am thinking 3:73
i think the car should go close to 140mpr in the 1/4
Old Jan 6, 2007 | 08:02 AM
rskrause's Avatar
It makes peak power at 7,000rpm? If so, 3.73 would be good.
Rich
Old Jan 6, 2007 | 09:13 AM
Rich
I am not sure where peak power is, on the dyno i stopped at 6500rpm and it was still going north
I was going to try and take it to 7000rpm if it is still making power
Old Jan 6, 2007 | 05:23 PM
CALL911's Avatar
If you have good drag suspension and you hook well, I say go with the 3.73's.
If you spin all the way through 3rd, go with some 3.42's.
Old Jan 6, 2007 | 06:13 PM
rskrause's Avatar
You need to estimate your trap speed and pick a gear to cross the line a couple of hundred rpm over the peak power. This typically produces the quickest/fastest times.
Rich
Old Jan 8, 2007 | 07:40 PM
john35thss's Avatar
Running almost mid 130's with 3.73 and 26 inch tire. if I had a 28 would run 3.9.
John
Keenan
Jan 19, 2023 12:24 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
blac94Z
29
Mar 25, 2015 04:21 PM
