coolant temperature sending unit
Old Dec 29, 2006 | 07:49 PM
arctic white 94's Avatar
Hello I have a 94 3.4 camaro.Here lately when I crank my car sometimes it idles at around 2000 rpms in park and 1500 rpms in gear.I can turn it off then back on then it acts normal.(guage works fine)I was told this could be the coolant temperature sending unit.Does this sound like the culprit and do you have to take it out of the car to check it.I did the ohms test while it was in the car and it was way off.I put one of the leads on the unit and the other on the positive battery cable is this right.Also to make sure there is only one of these coolant temperature sending units on the 3.4 camaros.
Thanks in advance for any help.
Old Dec 29, 2006 | 08:01 PM
2001NBMZ28's Avatar
Do you have a check engine/SES light?
Old Dec 29, 2006 | 08:18 PM
No there is no light.
Old Dec 29, 2006 | 09:29 PM
It could be something else so if any one knows what could be causing this problem please help.
Also I am checking the unit on the front of the left cylinder head.Is there another unit that tells the computer what to. could it be the coolant temperature sensor that would cause this.
Old Dec 29, 2006 | 10:18 PM
Someone please help me this is really bugging me.
Old Dec 30, 2006 | 08:04 AM
I cranked up my car this morning and it is now runnining rich with a rough idle.Is this related?
(plugs and wires are new)
Old Dec 30, 2006 | 12:02 PM
I cleaned out the IAC valve and now it seems to be doing better.It is idling smooth.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
adam85
Parts Wanted
May 20, 2015 10:50 PM
surreybrad
Apr 22, 2015 06:40 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
