Silly stupid injector question...
Old Dec 28, 2006 | 09:19 PM
Alex94TAGT's Avatar
My manuals are not located in the same city, so I'm in need of online help:
-I was under the impression that, when the key is turned to the ON position, the fuel pump primes AND the injectors fire several seconds-worth of fuel for initial startup. Is this correct?
-Or, do the injectors only fire while cranking, in conjunction with the optispark signals?
-(Or perhaps both above statements are true?)
It's a 1994 OBD1 LT1 TA. I'll post more info if deemed necessary, but this is a pretty generic question.
(Datamaster shows 0% DC while cranking, which I assumed to be normal. Physical inspection while turning key 'ON' produces no fuel out of the injectors, which I assume is not normal, so I'm a little SOL for the time being.)
Old Dec 28, 2006 | 09:30 PM
shoebox's Avatar
I don't think the injectors pulse until after there are signals from the opti. Datamaster injector duty cycle values are calculated, so it may not have enough info to do so just at cranking.
Old Dec 28, 2006 | 10:53 PM
There are no "cold start" injector pulses when you turn the key to on. The enrichment is handled by the PCM setting a richer mixture when it calculates the pulse width for cold start.
Old Dec 29, 2006 | 12:38 AM
Alex94TAGT's Avatar
That's exactly what I needed to know. Thanks to you both~
[Edit] And Whoops -- Didn't know we had a specific Fuel/Ignition forum now. I haven't been online much. Sorry Fred! (assuming you moved it for me).
GREEN3112
Feb 10, 2019 09:19 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
